1979 Ford F150 no front brakes
KD446
Brakes problem
1979 Ford F150 V8 Two Wheel Drive Automatic
have pressure on rear but none on front.just put new master but still nothing.
Apr 11, 2009 at 6:07 AM
MERLIN2021
  • 17,250 POSTS
If the Master is good, and bench bled properly, follow the steel lines to the proportioning valve, have some one hold the button in on the front of it while you bleed the brakes at the front axle.
Apr 11, 2009 at 6:11 AM
