I believe i have a tapping lifter how do i find out and how do i fix
Sep 13, 2009 at 8:19 AM
✓Experienced Mechanic
If the sound is on the top, chances are it's a lifter. Remove the valve cover to check if it could be a loose rocker that can be adjusted. If it isn't, the bad lifter will need replaced.
