I believe I have a tapping lifter how do I find out and how do I fix
Sunday, September 13th, 2009 AT 3:19 PM
MECHANIC
If the sound is on the top, chances are it's a lifter. Remove the valve cover to check if it could be a loose rocker that can be adjusted. If it isn't, the bad lifter will need replaced.
