HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Symptoms
Overheat
1971 Ford F-150 water in cylender
PSYCHONSOBER
MEMBER
1971 FORD F-150
Engine Cooling problem
1971 Ford F150 V8 All Boat Manual
I have water in #4 cylinder
Sunday, June 22nd, 2008 AT 10:35 AM
BLACKOP555
MECHANIC
Sounds like either a issue with a bad headgasket or more likely a leaky intake manifold gasket.
To find out if its headgasket perform a compresison test on a a few cylinders.
SPONSORED LINKS
Sunday, June 22nd, 2008 AT 12:22 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Truck Is Overheating
Engine Cooling Problem V8 Four Wheel Drive Automatic How Do You Bleed The Cooling System On A 2000 F150 5.4. The Truck Is Overheating I...
Asked by
mayo
2000
FORD F-150
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
Engine Overheating!
I Have A '98 F-150 With A 4.6l Triton Engine. Recently, I Took It To The Shop Because I Was Experiencing Overheating & Blow-back Of...
Asked by
jreid1998
1998
FORD F-150
1978 Ford F150 Engine Overheated
Greetings, Engine Overheated And Died. I Replaced The Intake Manifold, Distributer Armature, Intermediate Oil Pumd Shaft, Cap, Rotor. I...
Asked by
78ford
1 ANSWER
1978
FORD F-150
Over Heating Engine
I Have A 1984 Ford F150 With A 302 Engine. The Other Day It Got Over Heated And I Thought The Thermostat Was Stuck. I Removed The Thermostat...
Asked by
couldbejim
1984
FORD F-150
2000 Ford F150 Oil Problems
Engine Cooling Problem 2000 Ford F150 V8 Four Wheel Drive Automatic Until Recently I Have Noticed A Rather Big Problem. I've Had My...
Asked by
chaizer
2000
FORD F-150
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test
Online car repair manuals
