1970 Ford F150 all lights out
1970 FORD F-150
300,000 MILES • V8 • 2WD • AUTOMATIC
TERRIE TEARE
I have no brake lights, tail lights, turn signals, or backup lights. I heard a clicking noise from the passenger side of the firewall. I assume it was a relay. Would failure of that relay cause my light failure? I don't even know if there's a fused system on my truck. Any ideas on where to start?
Thanks!!
Terrie
Feb 24, 2010 at 10:31 AM
JDL
  • 16,098 POSTS
Hi, I don't have good wiring info for your model year. You might check applicable fuses with a testlite, make sure the fuses are good and the fuse circuit is hot, when it should be.
Feb 24, 2010 at 10:59 AM
CJ MEDEVAC
  • 11,004 POSTS
CHECK your SOLINOID for loose or broken wires.......follow POS BATT cable, solinoid on other end.
LOVE, TURDDOG
Feb 24, 2010 at 2:43 PM
