1962 Ford F150 camshaft
200,000 MILES • 6 CYL • 2WD • MANUAL
THEROADKILLBIKER
what is the corect oil pressure for the camshaft bearing which supplies oil to the rocker arm. Or what is the corect pressure for the rocker arm supply tube.
Jun 5, 2008 at 7:56 AM
MERLIN2021
  • 17,250 POSTS
Correct pressure for most engines is 40-60psi at 2000rpm, at the sender...
Jun 5, 2008 at 8:00 AM
