'01 F150 turn signal
BRITTANIESUE
I have a '01 F150 supercrew tilt steering and cruise control airbags the whole works, its just a regular F150 V8 5.4L engine mileage 150,000; My left turn signal is out we changed the bulb and it flashes in the back just not in the front, how do i changed the turn signal switch or do you think it is something else? INside the truck it blinks really fast with no signal in the dash.
Aug 28, 2007 at 12:40 AM
SKIBO1
  • 7 POSTS
try tilting the steering wheel all the way up and trying the signal then, if it works now then you have a bad connector on the mulitfunction switch (signal switch,wipers etc) ford sells a connector that you can install to repair this. what happens is when you tilt the steering wheel down the wires pull out of the switch and lose signal causing your concern
Oct 24, 2007 at 5:38 AM
