2002 Ford F-100 Transmission fluid
2002 FORD F-100
80,000 MILES • 6 CYL • 2WD • MANUAL
TILLEYKD
2002 Ford F-150 manual transmission. What type of fluid goes in this tranny? In older models I have always used gear oil but I read on newer ford tansmissions you should use ATF.. Does anyone know if this is true?
Aug 15, 2010 at 7:44 AM
Fluid Type Specifications
Manual Transmission Fluid Mercon ATF
Transmission Fluid Type
4R100 MERCON XT-2-QDX
4R70W MERCON V XT-5-QM
Aug 15, 2010 at 2:25 PM
