2002 Ford F-100 replace filter
2002 FORD F-100
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
SMITH10
I remove transmission pan found a yellow plastic part with o-ring on it in the bottom of pan. I can not find where it goes. please help me locate where this part goes.
Mar 14, 2010 at 5:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
that yellow plastic part is installed in the dipstick tube hole at the factory to hold the full load of fluid in the pan. When the dipstick tube is installed on the assembly line the plug is simply knocked down into the pan. You can throw the plug away.
Mar 14, 2010 at 6:13 AM
