1999 Ford F-150 Truck won't start, starter or ground wire p
1999 FORD F-100
160,000 MILES • V8 • 4WD • AUTOMATIC
THRICETRIO
The other day, my truck ran fine in the morning, then in the afternoon I went to start it and as soon as I turned the key in the ignition, nothing happened. The truck does click, but only once and doesn't try to turn over at all. I have had the battery tested and it was fine, and I've also changed the starter solenoid, but it didn't make a difference. This leads me to believe it is the starter, but I'm not very knowledgeable when it comes to cars. Someone else told me possibly a ground wire? But, as I said as soon as the key is turned, there is only one click, not repeated clicks.
Oct 8, 2010 at 5:21 AM
SATURNTECH9
  • 30,869 POSTS
I can't find a listing for a 1999 F-100 what model do you have?Also what is the 8th digit of your vin?Let me know so i can help you out.
Oct 8, 2010 at 5:48 AM
