1999 Ford Explorer major water leak
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
GARYLHAINES
I have a major leak coming from behind the water pump that i replaced. It seems its around the head gasket but no water in oil or water in exhaust. On the driver side of the engine what is there on that side that would cause such a leak. As soon as I pour water in it comes right back out. Is there a hose or bypass on that side or a freeze plug I cant see? what r ur thoughts. thanks
Nov 6, 2010 at 10:08 AM
CJ MEDEVAC
  • 11,000 POSTS
See my profile,
If this just started, after the pump change out
Maybe the pump is defective/ Or its not seating down right/ or you have PINCHED a WIRE, ETC, under it while installing the pump
The Medic
Nov 7, 2010 at 4:28 PM
