when I tried to add gas to the tank, the gas pump shuts off, like the tank is full, but it isn't, I can only put ounces of gas into the tank before the pump shuts down, service guy said the floating ball was froze? or stuck?
The first problem was, gas would leak from a hose leading to the tank, I had it repaired, $400.00. When I picked it up, it still leaked, took it back again, now when I try to add gas, the pump shuts off.
Jan 28, 2010 at 4:45 AM
