1994 Ford F-100 firing problem
148,000 MILES • V8 • 2WD • AUTOMATIC
JANHARIS
truck stutters at a steady pace when you give it the gas it will accelerate. Have checked the plugs and wires and distributer cap and rotor have replaced the coil and flushed the radiator what could be the cause the check engine light does not come on.
Feb 3, 2010 at 8:17 AM
RACEFAN966
  • 5,029 POSTS
Have you checked the EGR system or the TPS? If not do you have a digital multi meter? Get back to me.
Feb 4, 2010 at 1:36 AM
JANHARIS
No don't have a digital multi meter, my son will check TPS and ERG today
Feb 4, 2010 at 11:27 PM
RACEFAN966
  • 5,029 POSTS
OK if you need the procedure to check the TPS let me know I will get it to you.
Feb 5, 2010 at 1:29 AM
