1990 Ford F-100 Oil Pan Gasket
92,000 MILES • 6 CYL • 2WD • MANUAL
SCAIRL19
When replacing the oil pan gasket on the 4.9L engines on a 2 wheel drive F-150 do you have to raise the engine or anything or can the oil pan be dropped and removed with everything the way it is?
Mar 26, 2010 at 1:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you will have to remove the front engine mount bracket nuts from the frame insulators and raise the engine.
Mar 26, 2010 at 5:58 PM
