1990 Ford F-100 fuel pump
RONDWI
1990 Ford F-100 V8 Two Wheel Drive Automatic
I have 1990 ford f150. 5.0 engine. Dual tanks. I need to replace the fuel pump. Is the fuel pump in the front tank or is it in the rear tank?
Jun 5, 2010 at 2:38 PM
BLACKOP555
  • 10,386 POSTS
your vehicle has a pump in EACH tank. and dependent if your vehicle has a dual fuel tank selector valve you have a inline high pressure pump located about under the driver seat on the frame rail
Jun 6, 2010 at 6:19 AM
