1986 Ford F-100 no fuel pumping to engine
217,000 MILES • V8 • 4WD • AUTOMATIC
MATASAC145
i am getting power to my high pressure fuel pump but its not sending fuel to engine what could be the problem
Feb 28, 2010 at 9:52 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, you are getting power to it. Does it run when key it turned to on position?
If High pressure pump is working then need to check low pressure pomp that is in the tank.
Feb 28, 2010 at 10:10 AM
MATASAC145
it only worked with a jumper wire
Feb 28, 2010 at 10:28 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, in the engine compartment on the driver side firewall there is a Fuel Pump Cut-Off Relay. Check out link below for testing....
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Mar 1, 2010 at 12:23 PM
