1983 Ford F-100
HOLYWARRIOR
Electrical problem
1983 Ford F-100 6 cyl Two Wheel Drive Manual
my alternator is chargeing but no fire is going to my batt.i have replace the alternator twice and the voltage regalator and there is still no charge to the batt.what can i do?
Feb 14, 2010 at 5:56 AM
  • 75,988 POSTS
Disconnect the wiring connector on the voltage regulator and jumper A to F and see if it'll charge the battery
Feb 14, 2010 at 6:07 AM
HOLYWARRIOR
ok i did that and it started to charge but my batt. light is staying on .i think it might be over charging.
Feb 14, 2010 at 8:51 AM
  • 75,988 POSTS
If its overcharging best check the voltage regulator
Feb 14, 2010 at 9:27 AM
