1979 Ford F-100 ENGINE SHUT OFF
WBF1984
Electrical problem
1979 Ford F-100 V8 Two Wheel Drive Automatic
I HAVE REBUILT THE CARB AND REPLACED THE PLUGS,WIRES D.CAP,ROTOR BUTTON HOWEVER THE TRUCK CAN BE IDLEING PERFECTLY AND JUST SHUT OFF LIKE SOMEONE HITS A KILL SWITCH BUT WILL REFIRE MOST TIMES.
Sep 28, 2010 at 4:43 AM
  • 75,988 POSTS
Check and test the the coil, distributor pick-up coil, ignition control module-could also be the ignition switch-
Sep 28, 2010 at 9:54 PM
