1973 Ford F-100 Dies when i put in Reverse or Drive
48,000 MILES • V8 • 2WD • AUTOMATIC
GRUNERJUSTIN
My truck, which i recently got running, is having an issue with staying running when i shift it into gear. the truck will idle, all day if i wanted to. i have all new plugs, wires distributor, alternator, battery, fuel tank, fuel sending unit etc etc etc
the truck will fire up every time, and run all day but why will it not run when in reverse or drive? i can give it gas and then it will back up/forward but its a rough shift and i don't want to keep doing it as it will eventually damage my transmission. i was thinking a vacuum line but am unsure?
Aug 30, 2010 at 5:55 AM
CJ MEDEVAC
  • 11,000 POSTS
See My Profile, Imma Jeep Guy
I was roaming around and saw you---I know its 18 days late, I am a Member like you!---No pay either, but I may can still help, if you need it.
I'm Gonna throw you 2 links------Read The 1st one----------Read the 2nd page of the other.
These are Jeep CJs----Procedures are the same----Carbs different
If you can put up with my Boring---Out of sequence answers
I THINK YOUR CARB IS THE PROBLEM---Try to adjust it, like I describe.
https://www.2carpros.com/forum/1988-jeep-wrangler-engine-issues-when-braking-vt505041.html?highlight=
https://www.2carpros.com/forum/1985-jeep-cj7-stalls-when-hot-vt452051.html?highlight=
Return and let me know how it goes
The Medic
Sep 17, 2010 at 4:19 PM
