1993 Ford Explorer Warped Rotor Removal
STANGER987
  • 5 POSTS
i wanted take the rotors off of my explorer to have them turned and install new pads. do i have to remove the automatic lockers to get the rotors off?
my explorer is a 1993 4.0L 4x4 eddie bauer edition with 310 000 kms on it
thanks for any help in advance
Sep 14, 2007 at 3:36 PM
WRENCH
  • 57 POSTS
Yes and I would recomend a good repair manual to help you get it back, you should regrease the bearings since your there. So if you dont wont to use the manual just remember to do one side at a time and line all the parts in order of taking them off and reverse is back on. The cleaned parts and regreased bearings (should use new seals) back on the outside bearing needs to be seated, just snug up the bearings to seat then back off and then tighten to approx 15 ft lbs. that is about the same as tighting with your hand on the socket only no ratchet. Also with auto hubs I believe there is plastic parts so carfull not to break them and you might need a special socket for the hub nut.
Sep 14, 2007 at 4:29 PM
STANGER987
  • 5 POSTS
thanks for the advice. i didn't think that it looked like fun but somebodys got to do it. the next challenge will be finding that wrench. thanks again
Sep 15, 2007 at 3:01 PM
WRENCH
  • 57 POSTS
Also you can sometimes rent the tool from auto supply stores, or if your inclined to you can make the tool with an old socket and some grinding, if you take a look at it (just pull off the hub lock) see what it looks like you might be able to just make the tool.
good luck.
Sep 15, 2007 at 5:27 PM
Suggested Repair
Yes, the automatic hub locks must come off to remove the rotors. Use a repair manual, work one side at a time, and keep parts in removal order. Clean and regrease the bearings, preferably with new seals. Seat the outer bearing by snugging it, backing off, then tightening to about 15 ft-lbs (hand-tight on the socket, no ratchet). Be careful with plastic auto-hub parts and use or rent the special hub-nut socket; a modified old socket may work.
Conversation Summary
The owner of a 1993 Ford Explorer 4.0L 4x4 Eddie Bauer asked whether the automatic lockers must be removed to take the rotors off for turning and new pads. The expert confirmed they do, recommended a repair manual, and advised working one side at a time, lining parts up in order, cleaning and regreasing the bearings with new seals, and seating the outer bearing to about 15 ft-lbs. They also warned about plastic auto-hub parts and a special hub-nut socket, which can sometimes be rented or made from an old socket.
