Very loud engine squeal
K10SZEN
I have a 2002 4wd Explorer Sport, 83000 miles. 2 weeks ago driving home there was an extremely loud squeal coming from the engine. It started while I was on the expressway and continued for the next 30minutes only stopping while I accelerated. The next morning it stopped but started again in the afternoon when my air conditioner broke. I assumed that was the problem and I needed a new compressor. It air works now but the squeal came back yesterday. It only does this on my way home in the afternoon. Yesturday it would only stop when I was braking or stopped, today it is extremely loud again and stops only while I accelerate. I tried turning my air off and it still does it. My gauges are all fine and I have new brakes on my car. Any ideas? I would like to have an idea before I take it in some where.
Thanks!
Jul 20, 2007 at 6:14 AM
TRUCKINSOB2221
You might want to look and the bearings in your pulleys or it might be the fan belt.
Aug 16, 2007 at 8:02 AM
MIKE H R
  • 3,094 POSTS
check the belt for any wear spots. Check to make sure the belt is clean and properly alligned. If this is not the problem I would take the belt off and manually check the pulley bearings With the engine off , by tunring them to see if they are binding up , while you have the belt off check it. before putting the belt back on clean all the pulleys that the belt travels on. Just a little dirt or grease will let the belt slip and squeel
Aug 16, 2007 at 8:31 AM
