2006 Ford Explorer Octane Rating
TFMR
  • 10 POSTS
The manual of my Explorer2006 4.0L recommends 87 octane gas. I have been using 90 octane for over 3 month now. Could this cause any problems (in the long run even).
Will using 93 octane cause problems. Should I stick with the recommended 87 gas even though the higher octane gasolines are cleaner and smooth out the ride?
Jan 12, 2007 at 8:51 PM
INDYUKE
  • 416 POSTS
No, on the contrary. The higher octane you use, generally the less the engine suffers, the better fuel economy you get out of it and the smoother it runs. All of which translates into a longer lasting engine... if you also take care of it in other ways as well. I would say that recommendation by ford for the use of 87 octane means don't use anything less.
The best running truck I ever saw was a 1972 ford f100. The owner regularly ran 100 octane, low lead content aviation fuel in it. That engine was CLEAN!
Unfortunately 93 octane is expensive.
Jan 13, 2007 at 7:47 AM
Suggested Repair
No repair is needed. Using 90 or 93 octane should not cause problems; the 87 recommendation means do not use less. Higher octane may run smoother but costs more.
Conversation Summary
The owner of a 2006 Ford Explorer 4.0L asked whether using 90 or 93 octane instead of the recommended 87 could cause long-term problems, noting higher grades seem cleaner and smoother. The expert said higher octane generally reduces engine stress, can improve economy and smoothness, and that Ford's 87 rating means not to use less. The expert added that 93 octane is expensive.
