1999 Ford Explorer Pulls Right
PIRATE111
my girl friend just bought a 1999 explorerxlt 4.0 . they replaced all 4 ball joints and upper bushings and they said they couldnt do an alignment on the truck. Now the truck pulls to the right and some times when you give it gas it seems to pull both ways. someone looked at the truck for her and said it was the torsion bars and bushings. can the torsion bars cause this or is it something else. I was a mechanic for 15 years its been a long time for me i looked at the truck but i didnt see anything wrong with the torsion bars. toe in on the front passanger tire is out stabilizer bar and bushings seem fine the onei thing i can see was maybe the lower control arm bushings.
Oct 25, 2007 at 9:49 PM
2CARPRO JACK
  • 11,533 POSTS
Take it and have an alignment done.There must be a reason it has a toe problem on one side. Outer tie rod ends?Possibly lower control arm bushings (they ususally change camber)
Oct 26, 2007 at 8:21 AM
Suggested Repair
Have a proper alignment performed. Inspect the outer tie rod ends for the one-sided toe problem and check the lower control arm bushings, which can affect camber.
Conversation Summary
A 1999 Ford Explorer pulls right after all four ball joints and upper bushings were replaced, and the shop could not complete an alignment. Toe is off on the front passenger tire, and the truck sometimes pulls both ways under acceleration. Torsion bars were suggested, but the owner saw no obvious torsion-bar problem and wondered about lower control arm bushings. The expert recommends an alignment and checking outer tie rod ends and lower control arm bushings.
