1997 Ford Explorer Cannot put in park
BULL3T
Steering problem
1997 Ford Explorer V8 All Wheel Drive Automatic
I cannot put my explorer in park and then i can't pull the key out if the igniition whats the problem.
Jan 19, 2009 at 7:50 AM
RACEFAN966
  • 5,029 POSTS
I would say that something with the shift cable or linkage must be binding or the shift cable might be frayed and so it won't go all the way into park. If you haven't already I would look under the vehicle while someone moves the shifter and see what seems to be going on. I would also pull the center counsel to see what the shifter is doing there too.
Jan 19, 2009 at 11:39 AM
