1993 Ford Explorer Won't Go Into Gear
RIVETS MP
Yes, i have a 93 Ford Explorer, and wheni start the engine, i cant seem to get it into gear. I just had the slave receptical replaced. and the fluid drained and replaced. what else could the problem be?
Feb 21, 2006 at 10:32 PM
LOVESCARS
  • 359 POSTS
if you meant the slave cylinder have the system bleed again these are a pisser to bleed. i assume this is a manual trans
Feb 22, 2006 at 12:08 PM
Suggested Repair
If the slave cylinder was replaced, bleed the clutch hydraulic system again. These systems can be difficult to bleed completely. The advice assumes a manual transmission.
Conversation Summary
The owner of a 1993 Ford Explorer cannot get the vehicle into gear after starting. The slave cylinder receptacle was recently replaced and the fluid was drained and refilled. The expert recommends bleeding the clutch hydraulic system again and assumes the Explorer has a manual transmission.
