1998 Ford Explorer Rough Idle and Stalling
GAUR
I have a 1998 Ford Explorer 6cyl.SOHV with 71,000 miles. About 3wks ago it start to idle rough and would stall after stopping. I have had the fuel filter changed, new plugs and wires. New PVC valve,air filter and cleaned the throttle body. I had a mechenic check for vaccum leaks. None found. I also have put fuel injector cleaner in the tank. This happens when it is wet or dry out. What else can I look for or check?
Thank you for any help you can give me.
Randy
Aug 29, 2006 at 1:16 PM
SYNCRAIT
  • 235 POSTS
where do you live? i would first reccommend trying drygas because of the ups and downs in the temp it can create moisture in your tank causing poor performance....good luck lemme know :)
Aug 30, 2006 at 11:15 PM
Suggested Repair
Try a fuel dryer such as dry gas. Temperature swings can put moisture in the fuel tank and cause rough idle and stalling.
Conversation Summary
The owner of a 1998 Ford Explorer reports a rough idle and stalling after stopping despite a new fuel filter, plugs, wires, PCV valve, air filter, throttle-body cleaning, a vacuum-leak check, and fuel-injector cleaner. The expert recommends trying dry gas because temperature changes can create moisture in the tank and hurt performance.
