Rough Idle and Stalling
GAUR
  • FORD EXPLORER
I have a 1998 Ford Explorer 6cyl. SOHV with 71,000 miles. About 3wks ago it start to idle rough and would stall after stopping. I have had the fuel filter changed, new plugs and wires. New PVC valve, air filter and cleaned the throttle body. I had a mechenic check for vaccum leaks. None found. I also have put fuel injector cleaner in the tank. This happens when it is wet or dry out. What else can I look for or check?
Thank you for any help you can give me.
Randy
Tuesday, August 29th, 2006 AT 8:16 PM
SYNCRAIT
  • 235 POSTS
Where do you live? I would first reccommend trying drygas because of the ups and downs in the temp it can create moisture in your tank causing poor performance. Good luck lemme know :)
Thursday, August 31st, 2006 AT 6:15 AM
