1992 Ford Explorer Parking Brake Stuck
DENAREED
Ford Explorer, 1992, 118,000 mileage. My parking break is not releasing at all. I can reverse with no problem, but it will only let me jerk forward a few inches at a time. I'm wondering if there is some sort of temporary quick-fix I can do to release it so I can drive it to the mechanic. It's parked in a pay-garage right now and they gave me some problems about bringing a in a tow truck. Is this common on older Explorers? Thanks for your time.
Feb 14, 2007 at 9:27 AM
BHUGG
  • 157 POSTS
The parking brake is controlled by a cable that runs from the brake mechanism from the drivers seat to the rear brakes.
If you pulled the release and the pedal returns to the up position, then there is a problem in the cabling or the brake itself. If it doesn't return, then check the pedal and it's relase mechanism.
If the pedal releases, check the cabling to the rear wheels. If the cabling is loose (not tight) the probelm is in the brakes.
If it is in the brake themselves, you should get a mechanic to check it out.
Good luck
By the way, a parking BREAK is when you get that parking space right next to the store. You are concerned with a parking BRAKE.
Feb 17, 2007 at 2:37 AM
Suggested Repair
If the parking-brake pedal returns after release, inspect the cable to the rear wheels; a loose cable points to the rear brakes. If the pedal does not return, check the pedal and release mechanism. Have a mechanic inspect seized rear brakes rather than forcing the vehicle.
Conversation Summary
The owner of a 1992 Ford Explorer says the parking brake will not release, so the vehicle only jerks forward a few inches while reverse still works, and asks about a temporary release to reach a shop. The expert explains that the brake is cable-operated from the pedal to the rear brakes and advises checking whether the pedal returns, then inspecting the cable or rear brakes, with a mechanic needed if the brakes themselves are stuck.
