P1131 Code
WOULDUNO
2002 Ford Explorer 4.6L V8, Auto, 4x4, 59500 miles.
I have a code from my computer (P1131), which from what I have found indicates a lean condition. I have removed my front O2 sensors to visually check them for build up, they are clean. I have cleaned and re-installed the MAF, I also replace one suspect hose from my intake tube to a block box looking thing. I have also sprayed down the engine (while running) every place I could see a vacuum line to see if any leaks were prevalent using carb cleaner.
The vehicle starts, idles, and seems to run just fine. I have considered replacing the fuel filter, but I would think I would get the error on both banks and not just one. Any idea’s on where I should look next? Can it just be an O2 sensor?
Also, which side is bank 1 on this engine?
Thanks
Scott
Aug 7, 2007 at 2:53 AM
FRANK611
I have a 2002 XLT with the 4.6 V8 and 54500 miles. Got the P1131 code as well-regarding the service engine soon light. Took it to my shop they ran their own test and found that the upstream o2 sensor in bank 1 was bad. Total cost to repair was $200P/L plus $100 diagnostic fee total $300 to fix
Aug 13, 2007 at 6:05 AM
