1999 Ford Explorer check engine code for air blowing thru d
186,400 MILES • 6 CYL • 2WD • AUTOMATIC
SEANSTRAUSITY
Air conditioner blows cold,but blows thru the defroster vents up by the windshield & when i turn it on,it throws a code to "check engine"...code relates to the air conditioner.
Oct 15, 2010 at 3:04 AM
  • 110,251 POSTS
You are dealing with a vacuum leak in this case. The vent doors that direct air flow are vacuum actuated. Check under the dash for damaged or disconnected hoses. If you are lucky, you may hear a hissing sound with the engine running.
Let me know what you find.
Oct 15, 2010 at 4:23 PM
SEANSTRAUSITY
[quote:8960dad6f2="Jacobandnickolas"]You are dealing with a vacuum leak in this case. The vent doors that direct air flow are vacuum actuated. Check under the dash for damaged or disconnected hoses. If you are lucky, you may hear a hissing sound with the engine running.
Let me know what you find.[/quote:8960dad6f2] thanks bro i'll check it out...i already checked all the fuses...so i'll check for a vacuume leak,i'll let u know.
Oct 16, 2010 at 4:58 AM
  • 110,251 POSTS
Let me know. The vent doors won't set a check engine light.
Oct 16, 2010 at 3:19 PM
SEANSTRAUSITY
[quote:b1f4c7cf43="Jacobandnickolas"]Let me know. The vent doors won't set a check engine light.[/quote:b1f4c7cf43] ya,i've been told by several ppl its a vacume leak...the problem is there are manyl places that cud be leaking...i havent found any broken or disconnected spegettii hosses.
Oct 17, 2010 at 4:19 AM
  • 110,251 POSTS
They are a pain in the &^% to find. If you can stand the smell and can be really careful, take some starter fluid and spray it around the hoses. If there is a leak, it will cause the engine to rev-up. That is if the hose is still connected to the engine. However, please remember, keep the doors open for fresh air to you, and starting fluid is extremely flamable. Keep it away from anything that is extremely hot or could cause a spark.
Oct 17, 2010 at 4:56 AM
SEANSTRAUSITY
[quote:8247c08bc3="Jacobandnickolas"]They are a pain in the &^% to find. If you can stand the smell and can be really careful, take some starter fluid and spray it around the hoses. If there is a leak, it will cause the engine to rev-up. That is if the hose is still connected to the engine. However, please remember, keep the doors open for fresh air to you, and starting fluid is extremely flamable. Keep it away from anything that is extremely hot or could cause a spark.[/quote:8247c08bc3] hey thanks bro,i'll try it!
Oct 17, 2010 at 11:31 AM
  • 110,251 POSTS
You're welcome. Just be careful and let me know if you find it.
Oct 17, 2010 at 1:58 PM
