Oxygen Sensor
MARLIN
My check engine light comes on, I hook up my scan tool it brings up, P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) I have replace the drivers side oxygen sensor on my 1999 Explorer.
After a couple of days driving the check engine light comes on and the same code comes up.
Any idea whats going on here?
Jul 9, 2006 at 1:50 PM
TAURUSWHEEL
  • 718 POSTS
Any work done in the engine compartment before this happened??? Check all vacuum, air cleaner, maf tubing, pcv,, make sure all is in good shape,,, may have to it to dealer or good repair shop,, testing of the circuits involved and some of the info needed may be beyond the scope of the driveway mechanic,, since you've replaced the sensor and same issue has come up, possibly a circuit issue?? Have you put any fuel additives in your tank before this happened??? A rarity to be sure, but can affect certain components..
Jul 10, 2006 at 9:53 AM
