This problem has been baffling me for awhile, I have been getting what I feel to be very poor gas mileage from my explorer. The average approx mileage I am receiving is roughly 10 miles to the gallon. In the last 8 months I have had a tune-up, fuel pump replaced ( it failed on me), EGR valve replaced ( it too failed ), it has been looked at by Ford and they say it should be givng me excellent mileage ( I go roughly 300 kms on 60L of gas). I have noticed that my trans is takin time to engage in to reverse or drive ( round 5-6 secs ) and it was down in fluid roughly a month ago. Could my trans, if it is going, give me poor mileage?
1996 Ford Explorer Poor Gas Mileage
1996 Ford Explorer XLT, 157000 kms, 4.0 ohv.
Mar 30, 2007 at 3:59 AM
I think to be that poor you would have a driveability problem... do you get any feeling of the brakes dragging?
Mar 30, 2007 at 5:13 AM
No, I do not feel like that is happening. I have had the brakes completly renewed about 10 months ago ( pads,rotors and calipers)
Mar 30, 2007 at 7:31 AM
The main sensors involved in gas mileage are 02 sensors, But you have no codes?
Mar 30, 2007 at 9:43 AM
No codes at all and both O2 sensors are new. has me very baffled. maybe just wants to be my nemesis.
Mar 31, 2007 at 2:31 PM
try changing the temp sensor if this is bad PCM won't go into closed loop. This is as if you were running as a cold start all the time RICH.
Mar 31, 2007 at 2:33 PM
Have you checked your tire pressure?
Apr 3, 2007 at 12:02 PM
Suggested Repair
Check and replace the engine coolant temperature sensor if faulty, since a bad sensor can keep the PCM out of closed loop and cause a constant rich mixture. Also verify tire pressure. The delayed transmission engagement and prior low fluid should be checked separately.
Conversation Summary
A 1996 Ford Explorer owner reports about 10 mpg despite a recent tune-up, fuel pump, EGR valve, and new oxygen sensors, with no trouble codes. Brakes were recently renewed and do not feel like they are dragging. An expert suggested a faulty coolant temperature sensor could prevent closed-loop operation and cause a rich mixture, and another reply suggested checking tire pressure. Delayed reverse and drive engagement and previously low transmission fluid were also noted.
