1993 Ford Explorer
STANGCRAZY9969
  • 1993 FORD EXPLORER
  • 6 CYL
  • 4WD
  • MANUAL
  • 97,633 MILES
The explorer's gas mileage has dropped in half in the last two months. The tail pipe went from gray to black on the inside. Also it has a slight suction and miss sounding noise from the tail pipe. Have tried a oil detergent for a possible stuck intake valve but after 20 miles after using it, don't think it worked. A little loss of power and a littel jerky when driving
Monday, March 8th, 2010 AT 2:14 PM
  • 109,872 POSTS
It sounds like you have a plugged catylatic converter based on the sounds from the exhaust. Disconnect it to see if you regain the power. Also, let me know if the check engine light is on.
Monday, March 8th, 2010 AT 10:29 PM
STANGCRAZY9969
Yes the engine light goes on at random times while driving and goes off after about ten seconds. Also too old for diagnostic terminal under dash.
Monday, March 8th, 2010 AT 10:38 PM
