1994 Ford Explorer Black Smoke
ROBERTWES
  • 5 POSTS
I recently had trouble with my 1994 ford explorer with 195.000 miles also V6 4.0 liter engine.I went to auto zone to have a pcm check the manager said he could only do it to a 1996 and up not a 1994 i thought this to be a little strange. anyway i was told by a old mechanic who saw black smoke comming out of the tailpipe.He told me to put stop squeal in when i change my oil that will stop the smoke from comming out of the tailpipe
Mar 4, 2007 at 12:31 PM
TAURUSWHEEL
  • 718 POSTS
You need a different reader to access your codes, if any.. It probably costs around 30 bucks or so, easy to use.. black smoke is gasoline, too rich.. what the H is stop squeal??? Don't put anything in your oil especially since black smoke has nothing to do with oil..
Mar 4, 2007 at 2:09 PM
Suggested Repair
Use a code reader compatible with a 1994 Ford to check for codes. Black tailpipe smoke indicates a rich fuel mixture, not an oil problem, so do not add stop-squeal or other additives to the oil.
Conversation Summary
The owner of a 1994 Ford Explorer with a 4.0L V6 reported a transmission concern, was told a parts store could not scan a 1994 PCM, and was advised to add stop-squeal to the oil because of black tailpipe smoke. The expert said a different inexpensive reader is needed, black smoke means the engine is running rich on gasoline, and nothing should be added to the oil.
