Ford Explorer howls in cold weather
DENISE ELLIOTT
I have a 1995 Ford Explorer (2WD) that howls on cold mornings. The howling fluctuates in tone and volume but is not effected by RPMs or speed. It makes the noise whether it is idling or moving with the clutch in or out. I haven't noticed any difference in the performance or handling of the vehiicle.
Oct 26, 2006 at 2:33 AM
BRUCE HUNT
  • 3,754 POSTS
Take a look at the belts. Colder weather makes things drag more and a bad belt or loose belt will slip a little more.
Oct 26, 2006 at 3:45 AM
DENISE ELLIOTT
I have had fan belts make a screeching noise but this is not the same and the tone changes as well as the volume. The "howl" is more like something out of a sci-fi flick.
Oct 26, 2006 at 7:27 AM
NGARCIA
  • 7 POSTS
check your intake manifold. I had a 95 X and had the same symptoms. I cleaned out my manifold and it would stop temporarily.
Oct 30, 2006 at 1:12 AM
