Ford 1993 Explorer...Transmisson Humming
HB19572
My 1993 manual Ford Explorer is making little humming sounds and they are the loudest when I shift into 5th gear. Plus when I am in 5th Gear and I let off the gas the transmisson seemes to jerk. I looked under the car to see if any transmisson mounting bolts were loose, but there was not any. The sound seems to becoming from the transmisson, but I need help on how to fix or find the problem. Do you have any suggestions? Thanks!
Feb 21, 2006 at 9:12 AM
2CARPRO JACK
  • 11,533 POSTS
Post in the correct forum or your post will be removed
Thanx
Mar 1, 2006 at 9:53 AM
JPAM
  • 307 POSTS
bump**&moved 2 ford
Mar 3, 2006 at 7:01 PM
