EGR & Sensor access
GEORGERR
  • 9 POSTS
96 ExplorerXLT, 302V/8, 2wd, <100k miles Autoxmission
DTC P0402 EGR Flow excessive
Is there any way to get to the egr/sensor to remove and clean the egr and replace the sensor short of removing the portion of the throttle body that the egr is attached to? I just don't see how it can be done without special tools and then maybe not. I can't see the bottom bolt to the egr or two of the nuts that hold the sensor onto the egr.
Thanks for any input or help
George R
May 31, 2007 at 6:44 AM
RUDPRO
  • 224 POSTS
Click on this link. Hope it will help you.
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
May 31, 2007 at 8:07 AM
GEORGERR
  • 9 POSTS
Yep, I've already looked at that. Unfortunately, they only show the v6 not the v8. There is no room to work without taking something out, and from what I can see, it's going to be the throttle body.
thanks anyway
May 31, 2007 at 9:13 AM
