Don't know what's wrong with my truck.
There's a failure I can't identify for fixing.
It can be noticed only in two different situations:
a) after making a stop for a while and try to speed up faster, the engine do not responds quickly. Is like gas is not being fed to the engine.
B) On road, if I try to rush a vehicle, same thing happens, the engine do not responds. Like no gas is being fed to the engine.
In both situations, the engine is never shut off, but the capability to respond is decreased.
I already changed the EGR, VMV, EVR, spark plugs and cables. And the failure remains the same. ECU do not shows an OBD II code.
Any idea what could be causing this failure?
Thanks in advance for your kind help, I will really apreciate it.
SPONSORED LINKS
Monday, November 12th, 2007 AT 4:45 PM
