2000 Ford Explorer Burning Antifreeze
It is NOT a good sign and should be fixed asap or you will suffer engine damage. Water isn't compressable and can and will damge engine components.
Good luck
Suggested Repair
Have the engine inspected promptly for coolant entering the combustion chamber from a failed head gasket or a cracked or warped cylinder head, and repair it before engine damage occurs. Change the oil when the cylinder head is removed for the repair.
Conversation Summary
The owner of a 2000 Ford Explorer with a 4.0L V6 reports repeated coolant loss without visible external leaks, coolant in the oil, overheating, heater leaks, or excessive exhaust steam. A shop suggested a head gasket or cylinder problem. The expert says coolant is leaking into the combustion chamber from a bad head gasket or a cracked or warped head and should be repaired immediately to prevent engine damage. Oil-change frequency is unrelated, though the oil should be changed when the head is repaired.
