Air Suspension
LEV1017
1999 Explorer XLT 5.0L w/towing package - approx. 56,000 miles. Automatic Air Suspension load leveling worked fine until about a couple of months ago (used to be a little annoying when I'd get in and I'd hear the air pump engage to re-level the vehicle!) I checked the ON/OFF switch connection in the back and cycled it a few times, still no action. The "Check Air Suspension" light does illuminate upon startup, then goes off, as it always has. Anything else I can check before taking it in to dealership? Thanks!
May 7, 2007 at 10:30 AM
MERLIN2021
  • 17,250 POSTS
Check fude and relay in power distribution box under the hood...then listen for air leaks if the compressor runs...if it runs all the time tow the car and fix it...it will burn out the pump..then you are F____K_ED
May 7, 2007 at 12:26 PM
