2002 Ford Explorer sport. The air conditioning is blowing warm air when I turn on the A/C.
Saturday, June 17th, 2006 AT 2:48 PM
R'S GUTARS
MEMBER
Could be many different things. The easiest is to have the freon level checked. If it is out, there must be a leak. The clutch on the compressor could not be engaging. That could be a fuse, or the freon level, or the pressure sensor switch might be bad.
