1999 Ford Explorer Upper Arm Design
JMORG70
I recently replaced the front lower ball joints and this weekend hope to tackle the upper ball joints. On my vehicle the driver side upper ball joint is integral to the control arm, so I will be replacing the whole control arm with new bushings, not a problem. On the passenger side the control arm is a 2 piece design where you can replace just the ball joint. I have tried to get a whole new control arm assembly for the passenger side, but cannot find one. Everyone wants to sell me a one piece unit with the bushings already installed. Has the two piece design been replaced by the one piece or for this setup do I absolutely need the two piece design? If so would I need a different cam bolts to get the one piece design aligned? If the one piece control arm won't work could you guide me to where I could find the part number? Made a donation, please help.Thanks
Sep 20, 2007 at 3:00 AM
2CARPRO JACK
  • 11,533 POSTS
It has probably been updated to the one piece design (who knows why). Does the d/s have a one piece arm? Unfortunately for alot of the parts updates and th esuch, a trip to the dealer is req'd. And yes, you will have to get new eccentrics for the upper arm if you go to the one piece design
Sep 21, 2007 at 1:08 AM
JMORG70
Yes the driver's side is a one piece design. Any ideas on the new eccentrics. Either store or p/n.
Thanks
Sep 21, 2007 at 2:42 AM
2CARPRO JACK
  • 11,533 POSTS
Any place that does the alignment that it will need will have them.If you want, you can go to the dealer and get OE parts, but it isnt necessary.
Sep 21, 2007 at 10:22 AM
Suggested Repair
The passenger-side two-piece upper control arm has likely been superseded by the one-piece design. A one-piece arm can be used, but new eccentric cam bolts are required for alignment. An alignment shop or dealer can supply the eccentrics; OEM parts are optional.
Conversation Summary
The owner of a 1999 Ford Explorer is replacing the upper ball joints. The driver-side upper ball joint is part of a one-piece control arm, while the passenger side uses a two-piece arm and a matching assembly cannot be found. The expert says the design was likely updated to one piece and that new upper-arm eccentrics are needed for alignment, available from an alignment shop or the dealer.
