97 Explorer trouble code P0430
DAVID JAMES
Check engine light is on my 97 Ford Explorer, 4.0, V-6, sohc, automatic, 124,000 miles. It is reading a trouble code of P0430. PCM has determined that the catalyst system efficiency for bank 2 is below threshold for the current engine operating conditions. Engine is idling rough at startup then levels out. Any suggestions would be helpful.
Nov 17, 2007 at 8:16 AM
MERLIN2021
  • 17,250 POSTS
You may have a clogged or broken bed in the converter itself.
Nov 17, 2007 at 8:58 AM
