Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Warning Lights
Check Engine Light
96 ford explorer check engine light bulb
1996 FORD EXPLORER
FORERDM
MEMBER
seems my check engine light bulb is burned out.It will not show when starting engine.Is it easy to get to if i change it myself?
Oct 1, 2007 at 10:37 AM
BOOTDOG
Experienced Mechanic
you'll have to remove the cluster to replace the bulb. i haven't done one on ford before, i know some can be easy others a little tricky. good luck
Oct 1, 2007 at 11:13 AM
FORERDM
MEMBER
Thanks for your reply.Guess I will just start digging away.
Oct 2, 2007 at 11:18 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
