96 explorer
MRSOOP
Hi I have a 96 Explorer 130k mi 4.0 and when I put it in drive to accelerate it whines kinda and wont change properly the rpm run at about 3k at 70mph Im leaning towards the modulator but I can't locate it. I f you may have any visual help to locate it that would be great plus and alternative routes I may take in solving this problem or other things i should check please and thank you the sooner the better.
Nov 17, 2007 at 10:01 AM
BMRFIXIT
  • 19,053 POSTS
[quote:297fc3e05f="mrsoop"]Hi I have a 96 Explorer 130k mi 4.0 and when I put it in drive to accelerate it whines kinda and wont change properly the rpm run at about 3k at 70mph Im leaning towards the modulator but I can't locate it. I f you may have any visual help to locate it that would be great plus and alternative routes I may take in solving this problem or other things i should check please and thank you the sooner the better.[/quote:297fc3e05f]
under hood
check vacuum lines
check if any fluid around the vac lines
location of module
on the side of tranny under pass side by the cat convertor u will see a cover sheild
remove it
good luck
Nov 17, 2007 at 10:16 AM
