91 Ford Explorer XLT 4WD 4.0
1991 FORD EXPLORER
STEVENSECURE
  • 6 POSTS
I have a 1991 Ford Explorer XLT 4.0 4X4 that wont start. It has a new battery and started fine yesterday but now all it does is click one time when I turn the key. I am on a tight budget so if I could get a fairly definate answer I would be thrilled. Would it most likely be the solenoid or starter or what? thank you
Feb 9, 2007 at 10:46 AM
HRYK2646
  • 40 POSTS
I would start with checking your ground wire connectionfrom battery to block and connections to starter.You can test starter with jumper cables.may have got a bad one,or maybe egnition switch is bad.
Ray
Feb 9, 2007 at 12:53 PM
STEVENSECURE
  • 6 POSTS
ive checked the connections and the ignition switch is good so what else could it be???
Feb 9, 2007 at 5:57 PM
