2000 Ford Explorer Headlight Switch Fix
TAZMAN0548
where can I find the necessary (online ?) documentation to replace the interior rotary headlight switch?
what tools will I need?
Sep 20, 2006 at 5:20 PM
NOS
  • 320 POSTS
torx 15 driver,45 degree pick to take the knob off or even a small stright screw driver can do it.when you say rotory are you meaning with a thumb wheel or a knob a 9/32 socket a 5/16 socket. best way would be to get you a chilton book on your car it will give you step by step.(NOS) 8)
Sep 21, 2006 at 11:54 AM
Suggested Repair
Use a Torx 15 driver, a 45-degree pick or small straight screwdriver to remove the knob, and 9/32 and 5/16 sockets as needed. A Chilton repair book for the vehicle provides step-by-step documentation.
Conversation Summary
The owner of a 2000 Ford Explorer asked where to find documentation and which tools are needed to replace the interior rotary headlight switch. The expert recommended a Torx 15 driver, a pick or small screwdriver for the knob, 9/32 and 5/16 sockets, and a Chilton manual for step-by-step instructions.
