2007 Ford Explorer RPM
23,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILKE77
Hi, I have a 2007 Ford Explorer, the problem is with the RPMs'. When I initially start the vehicle the RPMs go to about 1200, then after 5-10 seconds goes back down to normal. After about a minute it jumps back up, then goes back down. Sometimes while I am driving and hit the brakes to slow down, it seems to want to accelerate by itself. Also putting it into gear to pull out of the driveway the accelerator is very touchy, bearly pressing it will send you back in your seat. Can you help?
Oct 6, 2009 at 11:13 AM
  • 110,248 POSTS
It sounds like the throttle position sensor. Has the check engine light come on?
Oct 7, 2009 at 12:23 AM
