Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Trouble Codes
P Codes (Powertrain)
P0300 - P0399
P0302
2007 Ford Explorer po302
2007 FORD EXPLORER
27,500 MILES • 6 CYL • 4WD • AUTOMATIC
SUZIEB712
MEMBER
1 POST
#2 cylinder misfiring
Jun 16, 2010 at 2:07 AM
RACEFAN966
Experienced Mechanic
Ok I do not see a question however I will let you know what can cause number 2 cyl. to missfire. It could be a bad plug, bad coil, or bad injector or worst case low on compression (which I doubt).
Jun 16, 2010 at 3:31 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
