2007 Ford Explorer Engine squeak
30,000 MILES • 6 CYL • 4WD • AUTOMATIC
NEILIO
The truck squeaks on start-up, idle, and while driving. the squeak gets faster with more gas and I think it's the main belt but I'm not sure.
Took it to mechanic and it was quiet for a few days after (thought it was fixed for good) and has now come back.
any ideas on a permanent fix?
will a new belt do it?
Sep 24, 2009 at 9:42 AM
MATHIASO
  • 1,209 POSTS
hello Neillo
tell me what did the mechanic replaced when it becomes quiet was the belt he replaced?
Sep 24, 2009 at 10:25 AM
NEILIO
He did not replace anything.
He said he roughed up (abraded) the belt surface so it would not squeak.
thanks
Sep 24, 2009 at 10:39 AM
MATHIASO
  • 1,209 POSTS
replace the belt and see what happened
if the noise still there after belt replacement, please contact me.
Sep 24, 2009 at 11:03 AM
  • 75,988 POSTS
He probably hit it with a belt dressing to calm it down could be very well be a driven component on its way out
Sep 24, 2009 at 11:23 AM
MATHIASO
  • 1,209 POSTS
yes you are right, it could be a problem with pulley allignement or alternator not align with other pulley.
it will be good to check pulleys.
Sep 24, 2009 at 11:35 AM
NEILIO
Ok thanks a bunch guys. I'm going to replace the belt and see what happens.
Sep 24, 2009 at 11:46 AM
